#1 2007-05-13 07:24
bobyang
Different languages and localization
I really love this software and more powerful but my friends use ant renamer becaue it has the laguanges they want. I am thinking to translater your renamer software to the language they want. is it possible to do so such as change an ini or xml file? thank you!
#2 2007-05-14 00:02
Re: Different languages and localization
Good to hear that! But unfortunately there are no language files for renamer. At the moment, translation can only be done with specialized programs like: Restorator, Multilizer, etc. (none of them are free). That is how Russian and Ukrainian versions were created.
#3 2007-05-15 01:10
bobyang
sad.. sad
is modifying the resource is the only way? i think I saw an open source resource editor before.. but that's is not so powerful to create ini or xml files..
do you think this will work? thanks
Resource-Hacker at softpedia.com
#4 2007-05-15 13:03
This Resource Hacker might work, but will require a lot of labor. You will have to go through each form definition (RCData section) and edit all Captions and Hints, also edit some strings (Strings Table section). It is possible, but the most annoying part about it is that if you do it for one version, it will not be portable for the next version.
You could try it to see how far you get with it...
P.S. It has a bug, I just notified the author. You not gonna be able to open the form definition for FORM_ABOUT.
#5 2007-05-15 20:35
bobyang
that's very true..I may need to modify it over and over again if there is new version of your software.. sad
do you plan to make your software able to choice different laguanges in the future? if so, I may wait to that time then tongue
thank you!
#6 2007-05-15 20:57
I was planning to add this a long time ago, but due the luck of free time and the underlining complexity - I always moved it for the future.
#7 2007-05-16 03:33
bobyang
thank you! please let me know if you are going to add languages. I will help that part for sure.
thank you!!
#8 2007-05-16 13:14
Ok, I will let you know when I add that multi-lingual support! smile
#9 2007-07-04 10:12
ozzii
Me too, I want to translate your great work.
I can do the French and/or Serbian translation.
You can contact me when the multi-language is OK.
_________________
#10 2007-07-06 16:47
