#1 2018-05-24 11:41
Stamimail
Drag & Drop folders/files and replace all existing
Currently Drag N Drop to Renamer is always appending items.
I think it would be better to make it like this:
The default Drag N Drop will replace the current list. No plus icon.
If Ctrl is pressed, then plus icon will appear and it will append items.
#2 2018-05-24 22:19
Stamimail
Re: Drag & Drop folders/files and replace all existing
Alternatively, by default will be the plus (append items), but when Shift is pressed it will replace the current list.
#3 2018-06-05 18:32
Thank you for the suggestion. It will be considered.
By the way, you can make ReNamer automatically clear all files on rename, by activating the relevant options in the Settings.
