#1 2018-05-02 14:24
G2DHT89RIDLW
RandPass - Remember (Last) Window Size And Screen Position Option?
Hi.
Is it possible to have RandPass remember the last window size and position?
Currently, if the generated password is 23 characters or less, it fits into the default window (using Windows XP).
But I regularly generate passwords of 32 characters or more and I have to resize the window.
But when I close RandPass and open it again, the window is back to default so have to resize again. It's a bit of a pain as I use RandPass multiple times a day.
If RandPass could be launched and the last position and size remembered, that would be great (and most software allows for this).
Thanks.
#2 2018-05-02 16:16
Re: RandPass - Remember (Last) Window Size And Screen Position Option?
Yes, of course, it is possible.
This will be implemented, it just wasn't high in the priority list.
#3 2018-05-02 16:27
G2DHT89RIDLW
Great. I shall look forward to it in a future release.
Many thanks.
#4 2018-06-17 13:45
This option has been implemented in RandPass 1.5.0.4 Beta.
#5 2018-06-17 14:12
G2DHT89RIDLW
Works great. Thank you.
