#1 2017-10-20 14:39
Anjaralova
Moving files automatically
I'm wondering how to move automatically files to a specific folder after renaming them.
Thanks a lot,
Anjaralova
#2 2017-10-20 14:47
Re: Moving files automatically
You can just insert the new path (relative or absolute) into the new name.
For example, insert "C:\New\Folder\" as a prefix to move all files to that location during the renaming operation.
#3 2017-10-20 19:18
Anjaralova
Hi Den4b,
Thank you for your help.
Regards,
Anjaralova
#4 2019-07-26 05:13
dannician
The above answer for adding a path prefix to move the copied files works for me.  Combine that with the new File:FolderPath on the Beta version and I am quite happy with the result.  There is a problem thought.  I want the moved images to be in the same sort order as the original folders they were moved from but they are all mixed up.  Is there a way to sort them in the same order that they were in before they were taken out of all the subfolders.  For example,
Folder 01\Image 1
Folder 02\Image 2
Folder 03\Image 3
After being re-named and moved to a new folder they would follow the same order without folders of subfolders.
NewFolder\Image1, Image,2 Image 3 ... same order with the folders and subfolders removed.
#5 2019-07-26 09:58
Sure, just use the Serialize rule.
You can also sort by the Path or other columns prior to applying the Serialize rule to ensure a particular grouping and ordering.
P.S. Your post appears to be a duplicate of a topic Keep moved files in same order as in parent folders after moving. Let's continue the conversation there.
