#1 2017-10-06 00:59
aip1000
[Bug Report] Presets Menu: File Extension Included when Sorting
Application Version:
6.7.0.6 Beta
Steps to Reproduce:
Create the following Presets:
  • Images
  • Images.Case
  • Images.Test
Expected Result:
The Menu Order should be:
  • Images
  • Images.Case
  • Images.Test
Actual Result:
The Menu Order is:
  • Images.Case
  • Images
  • Images.Test
Additional Information:
It looks like ReNamer is including the extension (.rnp) when sorting. ReNamer should sort by the file's base name without the extension so the Menu Order appears properly when the Preset Name includes spaces.
#2 2017-10-06 14:50
Re: [Bug Report] Presets Menu: File Extension Included when Sorting
Thank you for reporting this issue, and for producing a prefect bug report!
This will get fixed ASAP.
