Is it possible to resize the shutter window to make it smaller because when i use several shutters on my desktop i have not enough space,
and i need to have them visibles on my desktop to be reactivate automatically.
Thanks for your answer.
Paul
Hello Paul.
Shutter's default window size is quite small and fits on even the smallest desktops resolutions.
You can resize the main window as you do with any other windows, by dragging any sides or corners of the window with the mouse.
If you are still having problems, please send a screenshot which demonstrates your issue.
