#1 2017-09-15 09:34
noidea
Start a program after renaming files ?
I'm not a pro using renamer so far, so it might be obvious and I simple don't see it: I want to - for example - rename some mp3 files with renamer and automatically start mp3tag.exe with the set of renamed files after that. Is there a "click solution" for that ?
#2 2017-09-15 11:44
Re: Start a program after renaming files ?
You can use ReNamer's command line options for unattended renaming according to your preset rules and then start mp3tag.exe.
These commands can be saved in a BAT file for a one-click solution.
Something like that:
ReNamer.exe /rename "My Preset Name" "C:\Users\User\Music"
mp3tag.exe "C:\Users\User\Music"
