#1 2017-08-24 08:52
RazorBurn
Renaming Files According to a File Content..
Hi all,
Can someone help me make a script where a file will be rename according to a file content in a Antivirus Log File..
Example:
This a sample line content of a Scan Report from Kaspersky Total Security 2018..
24.08.2017 14.18.41	Object (file) detected	C:\Zip\VIRUS\New\065AD63D6E4246EE8219831C55A7B4E6DCF23693.EXE	File: C:\Zip\VIRUS\New\065AD63D6E4246EE8219831C55A7B4E6DCF23693.EXE	Object name: not-a-virus:Downloader.Win32.Somato.r
24.08.2017 14.18.39	Object (file) detected	C:\Zip\VIRUS\New\063BA2111709246C94B784F7DA952847D20B6930.exe	File: C:\Zip\VIRUS\New\063BA2111709246C94B784F7DA952847D20B6930.exe	Object name: HEUR:Trojan.Win32.Generic
24.08.2017 14.18.38	Object (file) detected	C:\Zip\VIRUS\New\057A2FCF7C45C53BB36CC2DC8EED371E1CD70393.exe	File: C:\Zip\VIRUS\New\057A2FCF7C45C53BB36CC2DC8EED371E1CD70393.exe	Object name: not-a-virus:HEUR:AdWare.NSIS.Xpyn.heur
24.08.2017 14.18.38	Object (file) detected	C:\Zip\VIRUS\New\05C04443C43C27F2728014817B1265594B79DBFF.EXE	File: C:\Zip\VIRUS\New\05C04443C43C27F2728014817B1265594B79DBFF.EXE	Object name: not-a-virus:HEUR:AdWare.MSIL.Imali.gen
24.08.2017 14.18.36	Object (file) detected	C:\Zip\VIRUS\New\02F1421A0B7784A42BE5B42E3A527041D5E3344E.EXE	File: C:\Zip\VIRUS\New\02F1421A0B7784A42BE5B42E3A527041D5E3344E.EXE	Object name: not-a-virus:Downloader.Win32.DownloAdmin.bupz
24.08.2017 14.18.29	Object (file) detected	C:\Zip\VIRUS\New\09C6B30B7FF918D54EE6DB72BF1BC41B5D6F1CA1.ZIP	File: C:\Zip\VIRUS\New\09C6B30B7FF918D54EE6DB72BF1BC41B5D6F1CA1.ZIP	Object name: Backdoor.Java.Adwind.cw
24.08.2017 14.18.29	Object (file) detected	C:\Zip\VIRUS\New\09C6B30B7FF918D54EE6DB72BF1BC41B5D6F1CA1.ZIP//plugins/Server.class	File: C:\Zip\VIRUS\New\09C6B30B7FF918D54EE6DB72BF1BC41B5D6F1CA1.ZIP//plugins/Server.class	Object name: Backdoor.Java.Adwind.cw
24.08.2017 14.18.29	Object (file) detected	C:\Zip\VIRUS\New\00DE86EF1C2638C5CDC696792C383702585842E3.EXE	File: C:\Zip\VIRUS\New\00DE86EF1C2638C5CDC696792C383702585842E3.EXE	Object name: not-a-virus:Downloader.Win32.Somato.r
24.08.2017 14.18.28	Selective Scan	Task started	Time: Today, 8/24/2017 2:18 PM
I need a script that finds its current filename in Report then rename the file according to the "OBJECT NAME:"
For example in the First line
FileName.Ext="065AD63D6E4246EE8219831C55A7B4E6DCF23693.EXE" ===> OBjectName="not-a-virus.Downloader.Win32.Somato.r + EXT"
Im absolute newbie in coding but can easily learn..
#2 2017-08-24 11:15
Re: Renaming Files According to a File Content..
Below is a script which will parse the report file and rename each matching file in ReNamer to its detected threat name.
Adjust the REPORT constant so it points to your report file. Also, you will most likely have many duplicated filenames and invalid characters in filenames. You can fix them using the standard renaming rules.
Now, learn... smile
  REPORT = 'C:\Temp\Report.txt';
  PATTERN = '\tFile:\s*(.+?)\tObject name:\s*([^\s]+)';
  MATCH_FILE = 0;
  MATCH_VIRUS = 1;
  SUBCONTENT_DELIM = '//';
  Initialized: Boolean;
  Matches, ReportLines, ReportFiles, ReportViruses: TWideStringArray;
  I, DelimPos: Integer;
  // Initialize
  if not Initialized then
    Initialized := True;
    // Read report file lines
    ReportLines := FileReadTextLines(REPORT);
    // Parse each line into Files and Viruses arrays
    for I := 0 to Length(ReportLines) - 1 do
      Matches := SubMatchesRegEx(ReportLines[I], PATTERN, False);
      if (Length(Matches) > MATCH_FILE) and (Length(Matches) > MATCH_VIRUS) then
        SetLength(ReportFiles, Length(ReportFiles) + 1);
        SetLength(ReportViruses, Length(ReportViruses) + 1);
        ReportFiles[Length(ReportFiles) - 1] := Matches[MATCH_FILE];
        ReportViruses[Length(ReportViruses) - 1] := Matches[MATCH_VIRUS];
    // Strip subcontent component from file paths
    for I := 0 to Length(ReportFiles) - 1 do
      DelimPos := Pos(SUBCONTENT_DELIM, ReportFiles[I]);
      if DelimPos > 0 then
        ReportFiles[I] := Copy(ReportFiles[I], 1, DelimPos - 1);
  // Find current file in the report and change its new name to a virus name
    if WideSameFileName(FilePath, ReportFiles[I]) then
      FileName := ReportViruses[I] + WideExtractFileExt(FileName);
      Break;
For the reference: http://www.den4b.com/wiki/ReNamer:Pascal_Script
#3 2017-08-25 02:21
RazorBurn
Thanks..
Added Destination Folder
  DEST_FOLDER = 'Renamed\';
      FileName := DEST_FOLDER + ReportViruses[I] + WideExtractFileExt(FileName);
      Break;
added rule for Invalid Char
added Serialize Duplicate
Just want to ask, as per Karspersky Virus Naming Procedure.. Duplicate name but different variant must be by letters, sample:
vir.exe
vir (2).exe
vir (3).exe
vir (200).exe
vir (201).exe
to
vir.exe
vir.a.exe
vir.b.exe
vir.aa.exe
vir.ab.exe
#4 2017-08-25 05:43
RazorBurn
Found the Solution for the Invalid Chars. and the Alphabathical Serialize for the Duplicate files
#5 2017-08-25 10:25
You might find useful a new option in the Serialize rule which allows you to select a different numbering system, including: Decimal digits (0..9), English letters (a..z), Roman numerals (I,II,III,IV,...), Simplified Chinese, Custom alphabetic and Custom numeric.
This option was added in ReNamer v6.7.0.2 Beta.
You can also do that with a simple Insert rule, to keep things more transparent.
