#1 2017-05-31 12:46
ReNumber rule: Increase / Add , Decrease / Substract number digits
Q: how can I do the math and add amount of x to existent numbers?
Test 3 2017.txt
Test 5 2017.txt
Test 9 2017.txt
Add 3
Test 6 2017.txt
Test 8 2017.txt
Test 12 2017.txt
Possible GUI for a new ReNumber rule:
Work on found number #: 1
         [_] Right-to-left
Math (Add/Substract/Fix): Add
           Math amount: 3
           [_] Allow negative result (else set to '0')
Add padding to length: 0
Explanation
The Rule should detect any group of coherent digits in a file name,
no matter how they are delimited, by space, hyphen, underscore, dot, char or any other sign.
Examples:
Letter 32.doc (NaN, Space, Number)
Letter 4 567 Draft.doc (NaN, Space, Number 1, Space, Number 2, Space, NaN)
Letter 2017-06-02 Draft.doc (NaN, Space, Number 1, Hyphen, Number 2, Hyphen, Number 3, Space, NaN)
The user tell the rule on which of the dedected numbers he want to work:
To make life easier, let the user declare wanted number counted from the right:
          [_] Right-to-left
Next he tell how he wants to calculate; increase, decrease or replace by a fix number, used for every file:
            Math amount: 3
            [_] Allow negative result (like '-4', else set to '0')
Next he tell which minimum number length he wants.
If the result would be shorter, zeros would be added to the left.
If the result is bigger as the wanted length, then that is fine too, no cutting down.
Maybe we have to add a rule before to split number into wanted parts first (and rule after to remove the split again)
Original:
  20170523064530.txt
Step 1: Rule to split by RegEx and add underscore to extract wanted part:
  20170523_06_4530.txt
Step 2: Rule to do the math (new suggested rule):
  Work on found number #: 2           [_] Right-to-left
  Math (Add/Substract/Fix): Add       Math amount: 1
  20170523_07_4530.txt
Step 3: Rule to remove underscore again:
  20170523074530.txt
Done.
################ PascalScript ################
In the mean time I have handicrafts a script for that issue.
"//// U S E R   S E T T I N G S" need to be adjusted in script for each different renaming task:
- RegEx pattern: Split file name into two or three parts, strRE := '(\d{8})(\d{2})(.+)';
- WorkOnPart: On which part of the split file name do you want to work, intPart := 2;
- Wanted amount to add / increase (or to substract / decrease), intAmountToCalc := 1;
- Math, do you want to add or to subtract, strDirection := 'add';
- Wanted length of the new number (pad to length), intNewNumberLength := 2;
- EDIT: Version 17.05.31b, added boolAllowNegativeResult := false
The code should handle the rest for you automatically (as far as I could think of)
Please test first and use on own risk.  ---  See examples in script.
(See our wiki for an how to using rules and scripts ReNamer:Rules:PascalScript)
////ReNumber_Increase_Decrease_Add_Substract_Digits.pas
////PascalScript for den4b's ReNamer (http://www.den4b.com/projects.php),
//// 2010-2019 by Stefan, Version 19.01.27
//// Version 17.05.31b: added boolAllowNegativeResult.
//// Version 17.05.31c: added better padding of short and/or negative number.
//// Version 19.01.27 : added better debug info and added possibility to insert a string to prevend duplicated names.
//// Found at: http://www.den4b.com/forum/viewtopic.php?pid=9982#p9982
////Purpose: Find number in file name and increase/decrease them.
////	!!! Adjust the script at "//U S E R   S E T T I N G S" to explain your needs	!!!
////EXAMPLE 1
// // //  FROM (here YYYYmmDDhhMMss.txt):
// // //  20170523064530.txt
// // //  20170523082330.txt
// // //  20170523101730.txt
// // //  TO (here increase hour by one each):
// // //  20170523074530.txt
// // //  20170523092330.txt
// // //  20170523111730.txt
// // //  USER Settings:
// // //  strRE := '(.{8})(.{2})(.+)';  //Split file name into two or three parts
// // //  intPart := 2; //Work on second part of split, here on "(.{2})" == 'hh'
// // //  intAmountToCalc := 1;  //Wanted amount to add or to subtract
// // //  strDirection := 'ADD';  //Do  add or subtract
// // //  intNewNumberLength := 2;  //Pad to minimum length of 2 digits, add zeros if need
////EXAMPLE 2
// // //  FROM:
// // //  786_red_socks_01.jpg
// // //  786_red_socks_04.jpg
// // //  786_red_socks_05.jpg
// // //  873_red_socks_12.jpg
// // //  873_red_socks_14.jpg
// // //  873_red_socks_25.jpg
// // //  TO (add 50 and pad to 4 digits):
// // //  786_red_socks_0051.jpg
// // //  786_red_socks_0054.jpg
// // //  786_red_socks_0055.jpg
// // //  873_red_socks_0062.jpg
// // //  873_red_socks_0064.jpg
// // //  873_red_socks_0075.jpg
// // //  strRE := '(.+)(\d{2})';
// // //  intAmountToCalc := 25;
// // //  strDirection := 'add';
// // //  intNewNumberLength := 4;
////EXAMPLE 3
// // //  FROM:
// // //  Magazine_01.jpg
// // //  Magazine_04.jpg
// // //  Magazine_05.jpg
// // //  Magazine_12.jpg
// // //  Magazine_214.jpg
// // //  Magazine_1325.jpg
// // //  TO (add 90 and pad to 4 digits):
// // //  Magazine_0091.jpg
// // //  Magazine_0094.jpg
// // //  Magazine_0095.jpg
// // //  Magazine_0102.jpg
// // //  Magazine_0304.jpg
// // //  Magazine_1415.jpg
// // //  strRE := '(.+_)(\d+)';
// // //  intAmountToCalc := 90;
// // //  strDirection := 'Add';
////EXAMPLE 4
// // //  FROM:
// // //  Counter 5.pdf
// // //  Counter 25.pdf
// // //  Counter 50.pdf
// // //  Counter 2555.pdf
// // //  TO (substract 7):
// // //  Counter 0.pdf
// // //  Counter 18.pdf
// // //  Counter 43.pdf
// // //  Counter 2548.pdf
// // //  strRE := '(.+?)(\d+)';
// // //  intAmountToCalc := 7;
// // //  strDirection := 'Sub';
// // //  intNewNumberLength := 0;
// // //  TO (negative result possible):
// // //  Counter -2.pdf
// // //  Use:
// // //  boolAllowNegativeResult := true
////EXAMPLE 5
// // //  FROM:
// // //  Vacation2015 - 1 - Lake Mounty Route 66.jpg
// // //  Vacation2015 - 2 - Lake Mounty Route 66.jpg
// // //  Vacation2015 - 3 - Lake Mounty Route 66.jpg
// // //  Vacation2015 - 4 - Lake Mounty Route 66.jpg
// // //  TO (add 99 and pad to 5 digits):
// // //  Vacation2015 - 00100 - Lake Mounty Route 66.jpg
// // //  Vacation2015 - 00101 - Lake Mounty Route 66.jpg
// // //  Vacation2015 - 00102 - Lake Mounty Route 66.jpg
// // //  Vacation2015 - 00103 - Lake Mounty Route 66.jpg
// // //  strRE := '(.+ - )(\d+)( -.+)';
// // //  intAmountToCalc := 99;
// // //  intNewNumberLength := 5;
////EXAMPLE 6
// // //  FROM:
// // //  8 Example 1234.ext
// // //  9 Example 1234.ext
// // //  10 Example 1234.ext
// // //  11 Example 1234.ext
// // //  TO (add 1, do not adjust padding):
// // //  12 Example 1234.ext
// // //  strRE := '(\d+)( .+)';
// // //  intPart := 1; //Work on second part
//// /END of examples.
/// T H E    S C R I P T
  SubPatterns: TStringsArray;
  intOldNumber,intPart,intAmountToCalc,intNewNumberLength,intCalculation: Integer;
  strRE,strDirection,strNewNumber,strNewName,strDuplicate: String;
  boolDebugOutname,boolAllowNegativeResult,boolDebugShowmessage: Boolean;
Begin
//// RegEx pattern:
//// Split file name (without the extension)  into parts (needs to be adjusted by user depending on file name pattern):
//// 	Split into two -or- three parts (base name only, no extension)
//// 		Two parts: (old number)( and the rest)
//// 		Two parts: (Before and )(old number)
//// 		Three parts: (Before and )(old number)( and the rest)
//     LName (PName) 19-200-01.txt
strRE := '^(.+ )(\d\d)(-\d\d\d-\d\d)$';
//// WorkOnPart:
//// On which part of the split file name do you want to work:
intPart := 2;
////Wanted amount to add / increase (or to subtract / decrease):
intAmountToCalc := 3;
////Math, do you want to add or to subtract:
/// use "add" -or- "sub" -or- "fix":
////Wanted length of the new number, taken from the right, add zero on the left if need:
////(Use "intNewNumberLength := 0;" to disable this feature)
////Add underscore signs before and after new number for better identifying in the preview?
//// True: Yes, please add them. // False: No, not need at all.
boolDebugOutname := False;
////Allow Negative Result?
//// True: Yes, please allow (e.g.: -3). // False: No, use zero '0' instead.
boolAllowNegativeResult := false;
////Show message box with details from current step in code:
boolDebugShowmessage :=false;
////Prevent duplicated file names, add a string, remove that afterwards yourself in a second run:
//// (Use a sign or string which is not a part of existent file names)
strDuplicate := '#'
//// /END of user settings
//// T H E   C O D E
////Split file name into parts (needs to be adjusted by user depending on file name pattern):
////function SubMatchesRegEx(const Input, Find: WideString; const CaseSensitive: Boolean): TWideStringArray;
  SubPatterns:=SubMatchesRegEx(WideExtractBaseName(FileName),strRE,false);
////Debug message:
IF(boolDebugShowmessage) Then ShowMessage('Amount of found parts: ' + IntToStr(Length(SubPatterns) ));
  If Length(SubPatterns) <=0 then exit;
////Work with found parts (Parts counting start at zero: Part0, Part1, Part2,...):
  intPart := intPart -1 ;	////decrease by one to translate from user wish to array rule.
  If intPart < 0 Then
	intPart := 0;
  intOldNumber := StrToInt(SubPatterns[intPart]);
////Debug message:
IF(boolDebugShowmessage) Then ShowMessage('Content of part: ' +  IntToStr(intOldNumber));
////Do the wanted configuration (use ONE of this three alternatives):
////IsMatchingRegEx(const Input, Pattern: WideString; const CaseSensitive: Boolean): Boolean;
If IsMatchingRegEx(strDirection,'sub', False)  Then	  //// substract / decrease (- intAmountToCalc):
  intCalculation := intOldNumber - intAmountToCalc;
If IsMatchingRegEx(strDirection,'add', False) Then	  //// add / increase (+ intAmountToCalc):
  intCalculation := intOldNumber + intAmountToCalc;
If IsMatchingRegEx(strDirection,'fix', False) Then	  //// add as fix number
  intCalculation := intAmountToCalc;
////Allow negative result (like -3) or not (use always '0' instead)?:
If boolAllowNegativeResult = False Then
	If intCalculation < 0 Then intCalculation := 0;
////Pad with zeros, if need:
If intNewNumberLength > 0 Then
		If Length(IntToStr(intCalculation)) < intNewNumberLength Then
			  strNewNumber := '000000000' + IntToStr(intCalculation);
			  ////Take the wanted amount of digits from the right:
			  strNewNumber := WideCopy(strNewNumber, Length(strNewNumber) -(intNewNumberLength-1), intNewNumberLength);
			  ////move minus/hyphen to the front:
			  If Pos( '-',strNewNumber) > 0 Then strNewNumber := '-0' + ReplaceRegEx(strNewNumber,'-','',False,False);
			end
		Else
			strNewNumber := IntToStr(intCalculation);
	end
Else
If boolDebugOutname = TRUE Then strNewNumber := '___'+ strNewNumber + '___';
SubPatterns[intPart] := strNewNumber;
////Compose new file name (be sure to add all wanted parts):
  If Length(SubPatterns) = 1 then FileName :=  SubPatterns[0] + strDuplicate + WideExtractFileExt(FileName);
  If Length(SubPatterns) = 2 then FileName :=  SubPatterns[0] + SubPatterns[1] + strDuplicate + WideExtractFileExt(FileName);
  If Length(SubPatterns) = 3 then FileName :=  SubPatterns[0] + SubPatterns[1] + SubPatterns[2] + strDuplicate + WideExtractFileExt(FileName);
End.
Thanks for making ReNamer.
If that script helps you, please see my signature if you are able to help Denis too, thanks.
#2 2017-06-02 17:16
Re: ReNumber rule: Increase / Add , Decrease / Substract number digits
Interesting idea!
It has been added as a new feature for future consideration, with a low priority.
Let's see if it attracts attention from other users.
#3 2017-07-10 08:41
Stamimail
I also needed to do arithmetic operations.
Currently I do it by:
1. Using Excel
2. Add Rule > User Input
#4 2017-08-08 23:26
Can you list the types of arithmetic operations that you needed to perform?
This will help shape up the rule, when the time comes to implement it.
#5 2017-08-08 23:52
Stamimail
I think in most cases I needed + or - (than * or /)
Anyway,
I think this kind of implementation will solve any type of query.
