#1 2017-05-09 10:16
Stamimail
Renamer on Tray
Renamer on Tray mode, will run Renamer in the system tray, and will let the user to use Hotkeys to execute a Preset on selected files in Explorer.
Mangae Preset will have another option - choose hotkey.
The user will:
1. Run Renamer.exe -On-Tray
2. Select Folders/Files in Windows Explorer
3. Hit a Preset hotkey for Rename
#2 2017-05-17 21:06
Re: Renamer on Tray
Tray icon will not be implemented.
This can be easily accomplished with explorer context menu integration. Create links for automatic renaming for each preset in the Send To menu, for example. Then you can select any files/folders and send them for automatic renaming via the context menu.
