#1 2017-04-24 10:32
andyvb
Load preset command line
It would be nice if you could specify in the command line the path where the preset can be loaded.
I don't think this is possible for the moment ?
#2 2017-04-25 11:06
Re: Load preset command line
It is already possible using command line parameters:
Shutter.exe /preset <preset>
Note that it will automatically start evening monitoring.
More info on the Wiki:
http://www.den4b.com/wiki/Shutter:Command_Line
