#1 2017-03-17 12:52
azarubkin
Storing original file name
What is the correct way to get the original file name, before rules execution? Is it WideExtractFileName(FilePath)?
My problem is: I'd like to check if the target file name exists and is newer than the one being renamed, and if so, cancel the rename (by assigning original file name to FileName variable).
The current setup is:
1. Remove certain substring from file name.
2. Execute script which checks dates and optionally cancels the renaming.
Is it OK?
#2 2017-03-17 15:06
Re: Storing original file name
That is correct.
Is it OK?
Yes, that is absolutely fine.
Have you experienced any issues?
#3 2017-03-20 10:06
azarubkin
No, just wanted to make sure I'm doing everything right :-)
