#1 2017-03-16 19:50
dm01
Ping Stops event is not working
Hello. I just want to turn off computer when wifi disconnects.
Network usage is not exactly what I look for.
I like "ping stops" idea but program pings only 1 time at start and don't continue to ping.
Please some help.
#2 2017-03-17 00:33
Re: Ping Stops event is not working
Please save your events as a preset and share it here or send by email.
Which version of Windows and Shutter are you using?
#3 2017-03-17 12:38
dm01
I can't attach so I uploaded drive.
drive.google.com/open?id=0B7BGBDfSM41vZ2VHc1BoaUNoQkk
I am using windows xp and shuttter 3.8.
I want to ping continously, and if ping stops, pc should turn off itself.
#4 2017-03-17 15:09
The problem is in your Ping Stops event configuration.
You need to enter "www.google.com" in the host name field, instead of "http://www.google.com".
#5 2017-03-17 16:23
dm01
that's cool solution !
Thank you.
