#1 2017-01-08 11:28
TGB
Fix conflicting new names - not cross-folder?
I added both files to the list and applied the "Fix conflicting new names" setup.
Both files got the same new name - IMG_20060618_030000.jpg.
I suppose this happened because they located in different folders.
If there is a option to ignore the location when using conflict name fixing?
#2 2017-01-10 22:53
Re: Fix conflicting new names - not cross-folder?
That is correct, the built-in option takes into account the full path of files when checking for conflicts.
However, a bundled "Serialize duplicates" script in the Pascal Script rule will do exactly what you need.
