#1 2016-11-18 11:53
Martin
How do I create and save to a new folder in batches?
Hi
I Have over a 1000 pictures in the format JPG which I have to sort. So far I have managed to sort them so I have a numerical order in the files that resets every 18th picture. Now I need to save every 18th picture to a new folder named numerical as in 1,2,3,4,5 and so on to a distination of my own choice. I found someone who asked a similar question but I didn't understand the answer to his problem which is close to mine. Please help. If I have 28 pictures then I need 18 of them to go into a folder named "1" and then remaining 10 pictures to go in a folder named "2".
#2 2016-11-18 12:19
Re: How do I create and save to a new folder in batches?
You can do this with a bit of Pascal Script magic (rule), using the following script:
  MAX = 18;
  Counter, Index: Integer;
  Inc(Index);
  if Counter = 0 then
    Counter := 1;
  if Index >= MAX then
    Index := 0;
    Counter := Counter + 1;
  FileName := IntToStr(Counter) + '\' + FileName;
This will prefix each filename with a numbered folder, which is incremented every MAX number of files (as defined in the script).
Here is an example of old and new names if MAX=5:
1.txt    1\1.txt
2.txt    1\2.txt
3.txt    1\3.txt
4.txt    1\4.txt
5.txt    1\5.txt
6.txt    2\6.txt
7.txt    2\7.txt
8.txt    2\8.txt
9.txt    2\9.txt
10.txt    2\10.txt
11.txt    3\11.txt
12.txt    3\12.txt
#3 2016-11-20 12:18
Martin
Thank you so much. It works big_smile. This just made my life so much easier big_smile.
