It´s a great work. Congratulations.
First I was about to post for a trim function (take off the spaces from the beginning of a folder or file) and then I realize that adding a CleanUp: fix spaces as the last rule solves my problem.
But I have one problem: add leading zeros to existing numbers.
Old file names
New file names (The values of the numbers stay the same)
This example is from 1-4a-Rename that have this function (just check and specify the number of leading zeros).
Two questions:
- Can I do this with PascalScript?
- Is it possible to have this function on future releases?
I'll post it as a sugestion too.
Thanks again.
Yes, it is possible to do with PascalScript, and the code is below. I will add this as a preloaded script in the new version. Just change the value of PAD_TO_LENGTH constant at the top of the script to whatever length you want all number sequences to be padded to.
PAD_TO_LENGTH = 3;
function CountDigits(const S: WideString; StartI: Integer): Integer;
var I: Integer;
Result := 0;
for I:=StartI to WideLength(S) do
if IsWideCharDigit(S[i]) then
Inc(Result)
else
Break;
function MakeZeros(Count: Integer): WideString;
var I: Integer;
Result := '';
for I:=1 to Count do
Result := Result + '0';
Start, Count: Integer;
Start := 1;
while Start < WideLength(FileName) do
Count := CountDigits(FileName, Start);
if (Count > 0) then
if (Count < PAD_TO_LENGTH) then
WideInsert(MakeZeros(PAD_TO_LENGTH-Count), FileName, Start);
Start := Start + PAD_TO_LENGTH;
end
else
Start := Start + Count
else
Inc(Start);
OK. That's it.
Thank you.
I just tried the "serialize duplicates" script and as I like to try things I mixed up the two scripts and that's what pop-up:
PAD_TO_LENGTH = 3;
Files: TStringsArray;
Files[Length(Files)-1] := S;
var I: Integer;
Result := False;
begin Result := True; Break; end;
var I, Qtos: Integer;
Qtos := PAD_TO_LENGTH - WideLength(IntToStr(Count))
Result := '';
for I:=1 to Qtos do
Result := Result + IntToStr(Count);
NewFileName: WideString;
Counter: Integer;
Counter := 1;
NewFileName := FileName;
while Exists(NewFileName) do
NewFileName :=
WideExtractBaseName(FileName) +
' ' + MakeZeros(Counter) +
WideExtractFileExt(FileName);
Counter := Counter + 1;
FileName := NewFileName;
Add(FileName);
I know that it's not the best and smartter code (have to set PAD_TO_LENGTH to number of leading zeros and Counter as the first number to serialize) , but it works.
If someone could help me to make it better I'll apreciate.
Sorry Denis, but I created a Frankenstein from your 2 codes
There is only one issue that I can see, without testing it: It will serialize all files which have a duplicate new name, EVEN if they reside in different folders. This problem has been solved in this topic: rename the same filename but different extension. But be careful, script from that topic ignores the extensions!
