#1 2016-09-23 23:34
rickyricky
Switch Folder Value Names Using ReNamer
I am trying to sort and/or copy folders and filenames under Windows 10. I am using a third-party software called ReNamer, which allows me to rename the folder however I want. I have two folders, called [AnyName1] AnyName2 and [AnyName3] AnyName 4. Is there anyway I could sort them so that it is arranged like this [AnyName2] AnyName1 and AnyName4 [AnyName3].
I want to be able to switch any name with the brackets with the one without the brackets. In addition, I want to be able to transform them by removing the brackets as well as adding by between the two names. Such as this:
AnyName 4 by AnyName 3
So far, I cam up with this: Replace expression "\A[(.?)](.)\Z" with "$2 by $1" (skip extension)
But it only lets me switch out with if the folders are only letters, not any name/string of the file. I want to be able to switch the words around regardless on how long they are each.
ReNamer Help
#2 2016-09-23 23:55
Re: Switch Folder Value Names Using ReNamer
You could use the following rules:
1) Regular Expressions: Replace expression "\A\[(.*?)\](.*)\Z" with "$2 by $1" (skip extension)
2) Clean Up: Fix spaces (skip extension)
It will work like so:
[AnyName1] AnyName2	-> 	AnyName2 by AnyName1
[AnyName3] AnyName4	-> 	AnyName4 by AnyName3
[The] Knocks	-> 	Knocks by The
#3 2016-09-24 00:10
rickyricky
Thanks for the reply but it still doesn't do anything for me.
Doesn't Work
#4 2016-09-24 00:12
You need to remove the double quotes from the expression and replacement pattern.
#5 2016-09-24 00:29
rickyricky
Okay now it works thanks.
Now what if I wanted it like this [AnyName4] AnyName3?
And if I wanted to revert them back?
#6 2016-09-24 00:51
Change the replacement pattern to "[$2] $1".
#7 2016-09-24 00:55
rickyricky
Thank you.
