#1 2016-09-06 20:21
Stamimail
If Name = New Name then skip
Why do I get a msseage that all files in list were renamed, instead of just the ones which marked in red (preview)?
#2 2016-09-06 22:34
Re: If Name = New Name then skip
Every marked file in the table will be renamed, that is just how ReNamer works.
#3 2016-09-06 22:38
Stamimail
What about an Option in settings to rename only the red ones?
#4 2016-09-06 22:56
There are multiple options to clear or unmark not changed files. Check the context menu.
#5 2016-09-06 23:03
Stamimail
Right.
wants to set the default behaviour... not to use always the context menu...
#6 2016-09-08 14:18
This option can be implemented. It was added to the list.
#7 2017-02-05 20:37
This option has been added in ReNamer 6.6.0.6 Beta.
#8 2017-04-19 11:37
Stamimail
I wonder why it's not the default. Why will someone want to keep disable "Skip renaming of unchanged files"?
#9 2017-04-20 01:11
One of reasons: It is a new feature which changes a long-established behavior. It may become the default in future.
#10 2017-07-20 00:33
Stamimail
I've noticed that after renaming there is an Information message that tells us how many files successfully renamed and how many files skipped.
The problem is that we can't know if the "skip" was made because there is no change, or because there were some disabled checkboxes.
I suggest
"X files skipped" for disabled checkboxes
"X files wasn't changed" for no change.
