#1 2016-09-06 20:09
Stamimail
How to: ABCX to => ABC"X
ABC = fixed characters
X = variable character ([A-Z])
'' = double '
#2 2016-09-06 22:33
Re: How to: ABCX to => ABC"X
Have you tried to use: Insert '' at Position 4?
If that is not what you need, then please provide complete examples.
#3 2016-09-09 14:13
Stamimail
ABCX is a word within words in Filename.
In list of Filenames, you can find this word in such cases: ABCA, ABCB, ABCC ... ABCZ
I want to add double apostrophe '' in front of the last letter, like that: ABC''X
#4 2016-09-09 14:27
This can be achieved with the following RegEx rule:
Replace expression "\b(ABC)([\w])\b" with "$1''$2"
Input:
Output:
ABC''X is a word within words in Filename.
In list of Filenames, you can find this word in such cases: ABC''A, ABC''B, ABC''C ... ABC''Z
#5 2016-09-10 23:26
Stamimail
Is the RegEx works for only English letters?
How to implement this for non-English letters? (the same example above, just the ABCX are non-English letters)
#6 2016-09-12 10:58
RegEx engine does understand Unicode characters which are specified explicitly, but character classes and meta characters such \w and \b currently work only with English character set.
Your task could be achieved with a PascalScript rule, but it will be a bit more complex.
#7 2016-09-12 11:48
This is the script that does it, but it will require the next development version of ReNamer (v6.6.0.1 Beta) because it uses newly added functions:
  QUOTE = '''''';
  Initialized: Boolean;
  ABC: WideString;
  Position: Integer;
  if not Initialized then
    ABC := WideInputBox('ABC', 'Enter your ABC sequence:', '');
    Initialized := True;
  if Length(ABC) > 0 then
    Position := 1;
    while Position > 0 do
      Position := WideTextPosEx(ABC, FileName, Position);
      if Position > 0 then
        if Position + Length(ABC) <= Length(FileName) then
        if IsWideCharAlpha(FileName[Position + Length(ABC)]) then
        if IsWideWordBoundaryLeft(FileName, Position) then
        if IsWideWordBoundaryRight(FileName, Position + Length(ABC)) then
          WideInsert(QUOTE, FileName, Position + Length(ABC));
          Position := Position + Length(QUOTE);
        Position := Position + Length(ABC);
