#1 2016-08-23 21:25
Cannelle
Filter with Regex
It be possible to load files using regex (instead of only matching extensions)?    Ex: load all files that contains adagio or andante...
#2 2016-08-23 21:30
Cannelle
Re: Filter with Regex
Similarly, is it possible to load (and also select once loaded) files that match some attributes (like Rating) or metatag (like Bit Rate)?
#3 2016-08-24 08:27
Hi and welcome, Cannelle.
Try 'Add Folders' > Browse to your folder > utilize 'Filter Settings' > Mask Include: *adagio*
See also
http://www.den4b.com/wiki/ReNamer:Addin … nd_folders
http://www.den4b.com/wiki/ReNamer:Menus … lters_menu
Another way is to first add all files and then use
http://www.den4b.com/wiki/ReNamer:Menus … Files_pane
Also you can utilize WinExplorer > Search box *adagio* > View Details > select and drag&drop to ReNamer
HTH? big_smile
#4 2016-08-25 08:05
Cannelle
Hi Stefan,
I found a way, by adding a rule that specifies the targeted files, marking only the modified files, and clearing all non marked.
But I think it would be more straightforward to allow regex as a filter.  Is this in the cards?
Thanks for your suggestions.
#5 2016-08-25 08:57
I don't know if den4b will add or already have full RegEx support to filter files to include.
But as shown and linked, you can use
*adagio*;*andante*
in the filter mask to match files with
'adagio' or 'andante'
in their name.
I tried f.ex. with "*span*;*ger*" to load all files with Spanish or German in their name.
#6 2016-08-26 10:05
Currently, include and exclude masks in the Filter Settings operate as wildcards.
RegEx based filtering can be implemented as an option, if there is a demand for it.
