#1 2016-08-16 21:34
bowflow
duplicate error: how to give a "-2" for duplicates
I want to give my photos the following name:
The rule is easy:
:EXIF_Date:__(:EXIF_Model:)
The problem:
sometimes photos are done so quickly, that there are "duplicates", because the cameras do not safe milliseconds......
first I tried to solve this problem with serialization at the end, but this is a bad solution, because if you delete one photo later, all photos will be renamed.
Best would be to give a "-2" ending only for duplicates.....
How do I solve my problem....?
#2 2016-08-16 22:12
bowflow
Re: duplicate error: how to give a "-2" for duplicates
Found it:
- "preview" and check the forth box from above
- (press F8  and change the meta-tags)
#3 2016-08-16 22:14
The easiest way to fix duplicated names is by using a built-in option.
Find Options menu just above the files table, click on "Fix conflicting new names".
#4 2016-08-16 22:17
bowflow wrote:
Found it:
That's right, you can also also activate that option after every preview.
