#1 2016-08-15 01:44
aip1000
$INCLUDE directive in PascalScript rules does not seem to work
I'm trying to organize the procedures/functions in my saved PascalScript rules.
As per the info in the Pascal Scripts: Tips section of the wiki, I'm using the {$INCLUDE 'filename.inc'} directive.
To test, I tried the following script:
PascalScript Rule:
{$INCLUDE 'Common.inc' }
  DoSomething(FilePath);
Common.inc:
procedure DoSomething(var Parameter: WideString);
  // Do something here with Parameter.
  // Original passed variable will be changed,
  // because Parameter has been passed as a Var.
  ShowMessage('DoSomething(): ' + Parameter);
Compilation fails with
Pascal Script Compile:
[Line 4] Error: Unknown identifier 'DoSomething'
So it seems as if that Common.inc file is not being included. I tried specifying a fully qualified path, but that doesn't work either. The script runs fine if I copy-paste the Common.inc into the PascalScript Rule itself.
Any ideas?
#2 2016-08-15 01:52
aip1000
Re: $INCLUDE directive in PascalScript rules does not seem to work
Sorry, please delete. I did not know it was only in the beta. For other users, ensure you are using 6.5.0.1
#3 2016-08-15 10:32
Added a version requirement in PascalScript Tips section.
