#1 2016-08-05 03:07
tylerheatherly
Using UserInput's "Load from Text File" in a Preset
I'm trying to use the "Load from Text File" feature of the UserInput function inside of a preset but I cant seem to figure out the proper syntax.  I have no problem in the GUI selecting a .txt file that contains a list of filenames, but I can seem to get the preset to load the same text file.
[Rule0]
ID=UserInput
Config=INPUT:"C:\replace.txt";ACTION:0;SKIPEXTENSION:0
Marked=1
I've also tried:
[Rule0]
ID=UserInput
FileName=C:\replace.txt;ACTION:0;SKIPEXTENSION:0
Marked=1
Thank you for your help,
Tyler
#2 2016-08-05 12:35
Re: Using UserInput's "Load from Text File" in a Preset
The option to load new names from a text file just loads the content and forgets the reference to a file. You can't force it by specifying a filepath, because it will be just interpreted literally as a new name.
If you require to load the file with new names dynamically before renaming each time, then you can use this PascalScript rule:
  FileWithNewNames = 'C:\names.txt';
  Index: Integer;
  NewNames: TAnsiStringArray;
  if Length(NewNames) = 0 then
    NewNames := FileReadLines(FileWithNewNames);
  FileName := NewNames[Index];
  Index := Index + 1;
Note that it will replace the entire filename including extension, and it interprets the content of the file using the current system locale.
#3 2016-08-07 09:19
tylerheatherly
Thank you so much for your help!  The PascalScript worked perfectly for my project.
