#1 2016-07-26 22:40
Team503
How to rename files from "Movie, The" to "The Movie"?
I'm assuming its some kind of Pascal Script, but I really don't want to learn a whole language just to do a single reformat of my naming schema.  Can anyone help?
#2 2016-07-26 22:53
Team503
Re: How to rename files from "Movie, The" to "The Movie"?
Strike that, found it:
http://www.den4b.com/forum/viewtopic.php?id=603
(Rename "the man.jpg" to "Man, The.jpg")
#3 2016-07-27 14:58
kunkel321
Yea, I think the "Rearrange" command would be easiest.  Otherwise, a regex would probably work.
#4 2016-07-29 12:21
For future reference, this can be achieved with any one of the following rules:
Replace: Replace using wildcards "*, The" with "The $1" (skip extension)
OR
Rearrange: Split by exact pattern of delimiters ", The", New pattern "The $1$2" (skip extension)
OR
RegEx: Replace expression "\A(.*), The\Z" with "The $1" (skip extension)
However, it's important to note that the RegEx rule will operate only if ", The" part appears at the end of the file name, unlike alternative rules.
