Hi, I have a 200+ files with file names lengths from 4-24 and am looking for a way to rename them all to 8 characters, while keeping some of their original filename. I tried "Insert" "Dos FileName", this worked for the files over 8 characters, but not on the ones under 8 characters, any thoughts?
1.) Use Insert: "#######" as Suffix to all file names (http://www.den4b.com/wiki/ReNamer:Rules:Insert)
2.) Use Delete: From Pos:8 to Till the End (http://www.den4b.com/wiki/ReNamer:Rules:Delete)
3.) Use Remove: "#" All (http://www.den4b.com/wiki/ReNamer:Rules:Remove)
See Preview how this works.
Thanks for the quick reply, this almost work, see attached
Ah, yes, you wanted all to be 8 chars long, and I thought one step to many.
(But why did "Use Remove: "#" All" let one sign left?)
Next try:
123456789.ext
123456.ext
12345678912345.ext
123.ext
12345678.ext
123456##.ext
12345678.ext
123#####.ext
USE:
2.) Use Delete: From Pos:9 to Till the End (http://www.den4b.com/wiki/ReNamer:Rules:Delete)
HTH?
Also see Options > Fix conflicting new names (to prevent doubled names)
That did the trick Stefan, thanks very much for your help
This is a regression introduced in v6.3.0.3 Beta.
It affected replacement of consecutive "Find" parts, where current position was incorrectly incremented by an extra 1 char, causing every 2nd consecutive "Find" part to be skipped.
This will be fixed in v6.5.0.3 Beta.
Well spotted!
