#1 2016-06-14 12:09
saurabhdua
What are the Applications of Colors? Who is the target group?
Hello There!
Excuse me for putting up... probably an Offending query..but what exactly does this Software aim to achieve, What is it used for, What are its practical applications, Who is the target group/users for this Software?
Secondly, Is it also possible to introduce "Metallic Colors" some day through this innovation? How about say--Metallic Red, Gold or Silver colors?
Replies will be genuinely appreciated.
Thank you.
#2 2016-06-14 20:45
Re: What are the Applications of Colors? Who is the target group?
What exactly does this Software aim to achieve, What is it used for, What are its practical applications, Who is the target group/users for this Software?
The aim is to provide a simple and efficient color picker. It allows you to select a color from a desktop or from various color maps.
It is mostly of interest for software developers, web developers, graphic designers, photographers, and other professions which involve working with digital colors.
Is it also possible to introduce "Metallic Colors"?
If you are talking about a standard definition of a Metallic color, then it cannot be reprodcued with a solid color.
Wikipedia.org wrote:
A metallic color is a color that appears to be that of a polished metal. The visual sensation usually associated with metals is its metallic shine. This cannot be reproduced by a simple solid color, because the shiny effect is due to the material's brightness varying with the surface angle to the light source. In addition, there is no mechanism for showing metallic or fluorescent colors on a computer without resorting to rendering software which simulates the action of light on a shiny surface. Consequently in art and in heraldry one would normally use a metallic paint that glitters like a real metal.
Maybe you have another definition?
#3 2016-06-15 08:24
saurabhdua
Dear Sir,
Thanks for the reply. All the very Best for on the ongoing project.
