#1 2016-06-12 16:05
TGB
Incorrect thousands separator
I am using ReNamer 6.5 Lite.
When I add 1211 files to the list at the bottom, the status bar shows me: 1?211 files.
I suppose it tries to show the thousands separator.
But I do not use this separator - it is set to ' ' (space) as Windows does not allow to set an empty char.
Please look into this issue - I expect to see "1211 files" or "1 211 files".
Windows XP SP3
#2 2016-06-12 21:30
Re: Incorrect thousands separator
Thanks for reporting this issue.
It should be fixed in v6.5.0.1 Beta, please try the latest development version.
#3 2016-06-13 18:03
TGB
Problem fixed, thank you.
