#1 2016-05-16 03:40
travis
Automating a preset to run as a scheduled job
Hi All,
I've completed a series of regular expression commands that I setup as a preset in Renamer and it all runs beautifully but my problem is that I have to manually load and run the preset at the end of the day but I need it to run automatically at different scheduled times. How can we achieve this?
Thanking you in advance.
Kind Regards,
#2 2016-05-16 08:07
Re: Automating a preset to run as a scheduled job
You can use command line options to automatically rename files using an existing preset.
For example:
ReNamer.exe /rename "My Preset" "C:\FileA" "C:\FileB" "C:\DirC" ...
There is also Main Menu > Presets > Create Links option, which creates similar shortcuts but without the files appended at the end.
