#1 2016-04-28 14:44
tek
Web Interface Kill Process
Is the kill process function through the web interface only available in the pro version?  Using the lite version I don't see it.
#2 2016-04-28 18:28
Re: Web Interface Kill Process
Yes, it is a part of the command line execution option in the Web Interface, which is only available in the Pro version. The option itself is located in the Web Interface settings tab.
If you need to kill the same process over and over again, you can create a preset that just kills that specific process and you will be able to run that preset via the Web Interface.
