#1 2016-04-28 11:35
Dirk
How to use "Hard Disk Usage" for external drives?
How could I use "Hard Disk Usage"
for an external drive? For example when an external 3,5 HDD has a usage of less than 1 byte / s a bat file shall be started to not to let the drive go to hibernation / standby.
#2 2016-04-28 14:24
Re: How to use "Hard Disk Usage" for external drives?
It's not possible at the moment to monitor usage of a specific hard drive.
However, to address your case you can just periodically write to a file on that hard disk to prevent it from going into sleep mode.
For example, you can setup Shutter like so:
Events:
1) Countdown: Wait 0:01:00
Actions:
1) Run Program: cmd /c "time /t > d:\temp.txt"
2) Utilities: Restart events
That basically writes the current time to "d:\temp.txt" file every 1 minute.
You can call other tools to write to the disk. This method uses native command prompt features, so it pops up a console window for 1 second every time its run, which can be hidden using HSTART tool.
#3 2016-04-28 15:26
Dirk
Alright, done, works perfectly.
Many thanks for your help. And thanks for HSTART.
