#1 2016-03-31 08:38
Colors 2.2
A maintenance update for Colors focused on multi-lingual and operational improvements.
Here are some highlights:
  1. Variable color picker spot size and selection of an average color.
  2. Enabled DPI awareness to fix form scaling issues on Windows 8 and later.
  3. Added 5 new languages: Japanese, Polish, French, Portuguese (Brazil), Spanish (Mexico).
The variable color picker spot size gives you options between 1x1, 3x3, 5x5, 7x7, 9x9 sizes.
For example, this is how a 5x5 spot size picker looks like:
Full list of changes:
* Added French language file. Thanks to Ozzii.
* Added Portuguese (Brazil) language file. Thanks to Igor Rückert.
* Resolve environment variables in custom storage path in Storage.ini.
* Enabled DPI awareness to fix form scaling issues on Windows 8 and later.
* Added Spanish (Mexico) translation file.
* Updated Chinese Simplified (zh_CN) translation file.
* Set application BidiMode (right-to-left) according to the selected language, instead of by system locale.
* Added BiDiCode setting in INI file for overiding application BidiMode, possible values: AUTO, LTR, RTL.
* Improvements to the registration procedure.
* Variable color picker spot size and selection of an average color.
* Refactored code for operation of color picker panel.
* Trim trailing new lines from system error message in file opening function.
* Added ability to take desktop screenshot on pre Windows 2000 platforms.
* Added Japanese translation PO file.
* Added Polish translation PO file.
* Updated copyright information.
