#1 2016-02-27 16:20
ReNamer 6.4
A big update for ReNamer which packs many user requested features and several important fixes.
Here are some highlights:
  • Added a new rule "Reformat Date" for changing format of date/time values in the filename.
  • Added "Whole words only" option to Remove and Replace rules.
  • Added German, Italian and Slovak user interface languages.
  • Change font size (zoom) inside of PascalScript window using Ctrl+Wheel.
  • Fixed incorrectly used system font colors in files table.
  • Multi-select rules with ability to remove, activate and deactivate.
Below is a visual example of how the new "Reformat Date" rule can help you finally fix all those random date formats in your file names.
Full list of changes in ReNamer 6.4:
* Change font size (zoom) inside of PascalScript window using Ctrl+Wheel.
* Upgraded development environment and external components.
* Fixed graphical glitches in rules list on Windows XP.
* Fixed incorrectly used system font colors in files table.
* Refactored layout and components of Reformat Date rule.
* Added a new rule "Reformat Date" for changing format of date/time values in the filename.
* Fixed potentially mangled content of PascalScript rule configuration.
* Adjusted the size of rule configuration components to better fit translated text.
* Fixed loading of translated text in the RegEx rule context menu.
* Resolve environment variables in custom storage path in Storage.ini.
* Scroll into view first matching file via "Select by..." context menu commands.
* Auto size columns in files table when they get enabled via context menu.
* Refactored replacement code in Case, Remove and Replace rules.
* Added "Whole words only" option to Remove and Replace rules.
* Corrected spelling of "UnMark" to "Unmark".
* Added icons to the Rules table context menu.
* Updated bundled copy of User Manual.
* Corrected spelling of DiscNo and DiscTotal meta tags ("Disk" vs "Disc").
* Fixed inconsistently changing state of "save filters with preset" option.
* Refactored code for managing user settings and preset configuration.
* Added hints for Torrent meta tags.
* Added context menu option for selecting all rules (Ctrl+A).
* Added rules multi-selection ability with group remove, activate and deactivate actions.
* Fixed a problem with meta tags being inserted at incorrect position in Unicode text.
* Added German language file. Thanks to Max Mehl.
* Added Italian language file. Thanks to Victor.
* Added Slovak translit file. Thanks to Slavo Gbur.
* Added Slovak language file. Thanks to Slavo Gbur.
* Updated Russian language file.
* Updated French language file. Thanks to Ozzii.
* Updated Japanese language file. Thanks to Tilt.
* Updated Chinese Simplified language file. Thanks to WanderMax.
* Internal optimizations and refactoring.
#2 2016-02-27 18:06
erebus
Re: ReNamer 6.4
Hello
thanks for the update and for the new rule "Reformat Date" very usefull
great job
thanks
#3 2016-03-21 01:33
jfe58
Re: ReNamer 6.4
Awesome update.
I just updated my laptop to Windows and 10 and installed the latest version of ReNamer.  Since I use ReNamer all the time, I realized I was still using the lite version.  I immediately went to your site and made a purchase.  Keep up the great work!
Joe
