I'm using 5.50 version as I found out that the pascal scripts which I'm using (a lot of them) do not work in the latest versions? I was testing only the latest free version, but I do not believe that it would be different in the pro version. Is it possible? Could you please explain what was changed? Why the old script are not working?
Lite and Pro versions will handle scripts identically.
Many things have changed since v5.50 (3 May 2009) - that is nearly 7 years ago now. You can inspect the Version History from the Help menu in ReNamer.
That is impossible to say without seeing your script.
1) OK
2) I believe they did and congratulation to it! ReNamer is really a successful project
3) Unfortunately that was the reason for me not to upgrade and I do not wan't to bother you with fixing all my scripts functionality. So far the 5.50 version does the job, however I'm always curious about the new features
Thank you for your reply and for moving the post to a new topic.
