#1 2015-11-05 11:22
bdpq
regular expression look ahead?
I was trying to use look ahead in regular expression:
.*?(?=ABC)
However Renamer gave me an error TRegExpr(comp) Unrecognized Modifier...
Is look ahead, look behind implemented in Renamer?
Thank you!
#2 2015-11-05 11:45
Re: regular expression look ahead?
Look-ahead and look-behind extensions are not implemented in the RegEx engine used in ReNamer.
All supported features are documented here:
#3 2015-11-05 14:37
bdpq
thanks~  I can work around it; however, any plan to include this feature in the future?
#4 2015-11-05 16:41
Not at the moment. The RegEx engine is a 3rd party package, so it will have to be implemented upstream.
#5 2018-10-31 00:56
eR@SeR
Hi Denis,
I also tried to use non-capturing group ?: but it is not supported. Is there any other RegEx library that can be used in ReNamer to support look ahead/behind assertions and non-capturing group?
