#1 2015-07-13 06:55
UksusoFF
More HTML tags?
Hi!
Can I rename files with html canonical or shortlink tag?
#2 2015-07-13 07:06
UksusoFF
Re: More HTML tags?
Meta tags also will be usefull.
For e.g.:
<link rel="canonical" href=" " />
<link rel="shortlink" href=" " />
<meta property="og:site_name" content=" " />
<meta property="og:type" content="article" />
<meta property="og:url" content=" " />
<meta property="og:updated_time" content="2015-01-05T13:56:36+04:00" />
<meta property="og:image" content=" " />
<meta property="article:published_time" content="2012-01-20T17:00:36+04:00" />
<meta property="article:modified_time" content="2015-01-05T13:56:36+04:00" />
#3 2015-07-13 17:19
Re: More HTML tags?
You can extract anything you want using a PascalScript rule.
For example, the code below extracts the content of <TITLE> HTML tag.
  REGEX_PATTERN = '<title>(.*?)</title>';
  Content: WideString;
  Matches: TStringsArray;
  Content := UTF8Decode(FileReadContent(FilePath));
  Matches := SubMatchesRegEx(Content, REGEX_PATTERN, False);
  if Length(Matches) > 0 then
    FileName := Matches[0];
It can be easily modified to extract any other portion of HTML file by changing the REGEX_PATTERN constant.
Note: The code assumes that the HTML file uses UTF-8 encoding, hence, the use of UTF8Decode function.
#4 2015-07-13 17:20
UksusoFF
Re: More HTML tags?
Thanks, I will try it.
