#1 2015-06-17 22:53
Hasher 3.2
This update for Hasher focuses on bringing in the multilingual user interface.
Translations for 5 languages are available at the moment:
  • Chinese Simplified - by WanderMax
  • Italian - by Marino de Stena
  • Portuguese (Brazil) - by Igor Rückert
  • Romanian - by Florin David
  • Russian - by Denis Kozlov
Don't see your language here? Check out Localization guide if you would you like to create a translation for your own language.
Full list of changes in Hasher 3.2:
* Added Chinese Simplified (zh_CN) translation file;
* Added Italian (it) translation file;
* Added Romanian (ro) translation file;
* Changed full language title from "Title (Native)" to "Title - Native";
* Added Portuguese (Brazil) translation file;
* Added multilingual support using PO files in Languages folder;
* Added Russian language file;
* Fixed encoding mix-up in registration data handling;
* Added high resolution icon 256x256 and cleaned up 16x16;
* Adjusted positioning of components to better fit localized text;
Online
