#1 2006-06-15 08:13
LawOfNonContradiction
Renamer: PascalScript: before or after dash
For filenames containing one dash I want to keep the longer portion ignoring the extension and make lowercase.
If  ReallyLong-short.avi then  ReallyLong.avi
If  this-thatotherthing.avi then thatotherthing.avi
From your example I created this kludge:
  BeforeDash, AfterDash: string;
  Marker: Integer;
  Marker := Pos('-', FileName);
  if (Marker > 0) then
    BeforeDash := Copy(FileName, 1, Marker);
    AfterDash := Copy(FileName, Marker+1, Length(FileName));
    if (Length(AfterDash) > Length(BeforeDash)) then
          FileName := LowerCase(AfterDash);
    if (Length(BeforeDash) > Length(AfterDash)) then
          FileName := LowerCase(BeforeDash);
Its not working as I expected.  It seems to be doing the opposite.  The TryToCompile button was helpful.  I left out a few begins and thens the first time through.
#2 2006-06-15 08:21
Re: Renamer: PascalScript: before or after dash
hmm.. if BeforeDash is longer this retains BeforeDash AND the dash itself.  I don't want the dash.
  Marker: Integer;
          FileName := LowerCase(AfterDash) + LowerCase(ExtractFileExt(FileName));
          FileName := LowerCase(BeforeDash) + LowerCase(ExtractFileExt(FileName));
sure I can use a remove rule, but for the purpose of this exercise I'd like to do it within PascalScript wink
#3 2006-06-15 10:32
Hi Law of NonContradiction,
Yes, you missed few little things.. For example, AfterDash will always contain the extension, and BeforeDash string will always contain the dash at the end. Anyway, here is the code that will do it the way you want it smile
  BeforeDash, AfterDash, Extension, BaseName: string;
  Marker: Integer;
  BaseName := ExtractBaseName(FileName);
  Extension := ExtractFileExt(FileName);
  Marker := Pos('-', BaseName);
  if Marker > 0 then
    BeforeDash := Copy(BaseName, 1, Marker-1);
    AfterDash := Copy(BaseName, Marker+1, Length(BaseName));
    if Length(AfterDash) > Length(BeforeDash) then
      BaseName := LowerCase(AfterDash);
    if Length(BeforeDash) > Length(AfterDash) then
      BaseName := LowerCase(BeforeDash);
    FileName := BaseName + Extension;
#4 2006-06-15 10:38
By the way, it's nice to see people playing with PascalScript rule smile
It can get very interesting, functionalities and possibilities of this rule - are unlimited!! big_smile
#5 2006-06-15 22:24
dloneranger
You're not wrong smile
Last week a friend was here and during his stay he moaned about some files he had downloaded that were split into parts
I fired up delphi and talked him through what to do, trying to explain the reasons and getting him to understand it
Honest to god it was like christmas - seeing the look of delight on his face after writing his first program and having it work was wonderful
#6 2006-06-15 23:12
Qkid
Yeah Pascalscript is very good smile
If you need a program to manage mp3/audio files then try this:
The Godfather : http://users.otenet.gr/~jtcliper/tgf/
It has Pascalscript support and i've used it to write a script for outputing txt files etc with file info.
My TGF mirror is at: http://audiooctopus.planetmungo.co.uk/tgf/
Finally this site helped me a lot to revise the Pascal syntax, http://www.delphibasics.co.uk
#7 2006-06-15 23:33
dloneranger
If you can i'd recommend finding a personal edition of delphi to play with - pascalscript is very nice but a full version is nicer
I guess i'm lucky here, I get the top notch version to mess about with - I guess I should use it for database work, but there's always a few hours a day when I can squeeze in the things I want to do
#8 2006-06-16 14:45
Are you that lucky?.. Did you get BDS 2006 ? yikes
I'm still on Delphi 7, I like it, and my computer likes it as well tongue
#9 2006-07-17 13:12
ohhhh "ExtractBaseName"... that helps a bunch.  smile  thanks
