#1 2014-09-26 16:15
rkrater
Request : Create Folder
Hope you consider adding the option to create a folder based on the ReNamed file name.
So : File123.txt  would be File123\File123.txt
#2 2014-09-26 19:45
Re: Request : Create Folder
I rather think he do not have to.
#3 2014-09-26 21:50
rkrater, you can do so already either using PascalScript or simply inserting a meta tag as follows:
:File_BaseName:\
