#1 2014-09-24 10:34
derekz
[action request] Screenshot
Hi
Is possible to add an action "screenshot" (screen capture)?
#2 2014-09-25 18:36
Re: [action request] Screenshot
Good idea, it's added to the list of features for future.
What kind of options (configuration) would be useful for this action? For example: path where to save, timestamp all files, format, etc?
#3 2014-09-26 11:04
derekz
I think options can be
Path
format (jpg,png)
Filename
Choose from Timestamp on filename or sequential number
last option (but you can add it on the future) is a very small text over the image
where you write the events that generated the action.
Thank you for your attention.
#4 2017-01-18 10:23
Grendizerus
This feature is not implemented yet, in v3.8, right?
#5 2017-01-18 10:52
Not in v3.8, but it is being worked on. It will be available in the latest development version soon.
#6 2017-01-18 15:38
derekz
2.5 years... go Den go big_smile
#7 2017-01-20 00:11
Better late than never wink
#8 2017-01-31 11:39
