What folder are rules stored in and is it possible to copy them from from that folder?
I just had to reinstall to an old backup of Windows 7 and lost all the rules that I had saved in ReNamer, I do however have my old C: drive backed up and was wondering if I could copy all of my rules from there to my new installation of ReNamer?
Thanks in advance!
Hi, do even ReNamer store rules at all for you in the meantime?
We still have got no feedback from you about your last question 3 years ago.
The ini is still stored in the program folder.
But if you are not familiar with your operation system they may be stored elsewhere even without your knowledge.
Please take a look if reading this threads will give you a glue:
http://www.den4b.com/forum/viewtopic.php?id=1884
http://www.den4b.com/forum/viewtopic.php?id=1224&p=2
Oh, there is even a wiki post about this issue:
http://www.den4b.com/wiki/Compatibility
Hi Stefan,
Thanks for the quick reply, sorry I never replied to my last post, it worked fine once I moved to do a different directory. I will reply to that fact for other people who might come across that post.
As for this problem, I followed the following post:
I copied the default presets from the location specified in my back to my current installation and everything worked fine!
Thanks again for your help excellent product!
