#1 2007-04-15 18:30
reverett
Change filename to reflect modify date/time of file
I'm wondering if it's possible to have ReName change a filename to reflect the date/time stamp (modified date/time preferred) of the file itself. If so, is there an example of how to do this?
Thank you,
Randall
#2 2007-04-15 19:08
reverett
Re: Change filename to reflect modify date/time of file
I found a post I beleive will help me. Thanks!
#3 2007-04-22 09:09
Just to note that date/time stamps can be accessed via the meta tags (in Insert rule): File_DateCreated and File_DateModified.
Date/time format can be changed in the Settings.
