#1 2014-08-14 18:42
TheDutchJewel
Preview filter to show only changed file names
The preview option to higlight changed file names, is very handy.
But if you rename hundreds/thousands files at once,  it would even be handier if it was possible to filter the preview to show only the changed file names.
I hope you will add this function soon.
#2 2014-08-14 18:53
Re: Preview filter to show only changed file names
Is now soon enough? wink
http://www.den4b.com/wiki/ReNamer:Menus … ar_submenu
Clear submenu
Note: The term "Clear" means remove from Files pane of ReNamer.
Clear Failed
Only files that failed to rename (those with an x mark) will be cleared.
All other files (including files whose names were not altered by the rules) will remain in the Files pane.
#3 2014-08-14 19:08
TheDutchJewel
Wow, thanks!
Ctrl+D to Clear Not Changed.  smile
