I tried to sort the error column but it did nothing.
The two new columns "Error" and "Old Path" didn't actually have comparison methods implemented, until now.
Please try latest dev version: v5.75.5 Beta.
P.S. The error column is not going to be sorted by textual message, instead the internal error code is used for sorting which then maps to an error message.
