#1 2014-05-12 04:42
currimundi
Cannot add files because of masks
I have used Renamer in the past, about a year ago.   now I cannot add files to be renamed,  i have tried the 'add files' button, dragging files, and copy and paste files, and 'add folders' button,   for some reason they do not appear in the bottom section,  I have now upgraded and reinstalled but there is no change.    I have win 8.1  64 bit and am using version 5.75 lite non commercial version.
anyone have a solution i can try??
John  big_smile
#2 2014-05-12 11:24
Re: Cannot add files because of masks
First thing is to check the Filter Settings...
Make sure that you have no Masks defined, because this can potentially filter out all files.
#3 2014-05-13 00:28
currimundi
Thanks for your reply... the filter mask is set to avi;mp4;flv;mkv;, (these are the type of file i'm adding)  this must be the default as i have not changed or added anything.
John hmm
#4 2014-05-13 00:47
currimundi
Hi again,  I have deleted the  avi;mp4;flv;mkv; that was in the filter mask and I am now able to add video files, which is good,  thanks again.
John smile
#5 2014-05-13 08:14
You didn't have correct masks. It should be:
*.avi;*.mp4;*.flv;*.mkv
Your previous set of masks matched only files which were actually named "avi", "mp4", etc.
#6 2014-05-14 00:53
currimundi
It works ok without any filter masks, so I'll leave it at that.   thanks again  smile
