#1 2014-03-23 16:43
therube
Compare Hash - Cycle Through All Enabled Hash's For Comparison
Why not have the Compare function automatically check any enabled Hashes & compare against all of them, rather then needing you to specifically click a particular hash/compare button combination.
I've got a number of hashes selected.
I've copied the hash value from the website.
I download my file & drag it into Hasher.
Instead of even realizing the website's hash method, instead of clicking a specific Compare button, I just click a single Compare Hash button & Hasher cycles through all the enabled hashes & compares.
If a match is found, it could display that pair.
If a match is not found, it could display the hash value & all the non-matched values.
#2 2014-03-27 21:45
Re: Compare Hash - Cycle Through All Enabled Hash's For Comparison
Implemented in v3.0.0.3 Beta.
There is an checkbox in the Compare dialog to allow comparison to any of the available hash types.
