#1 2007-03-22 13:48
Newt
Swap Parts Of The File names
Hiya,
Is there a way that I can swap parts of a file name? Maybe by using a delimiter? For example if I have file names like this
King, Stephen
Cook, Robin
Rami, Sam
I want to be able to switch them to this
Stephen King
Robin Cook
Sam Rami
The PascalScript Move Filename Portion doesn't really help because the file names have different lengths.
If there is no way to do this presently I would like to request it be added in the next release.
Thanks for the great program.
#2 2007-03-22 21:05
Re: Swap Parts Of The File names
Yes, there is an easy way to swap parts like that, read one of these topics:
Move pattern to start (prefix), Swapping words within a file name.
You need to use Regular Expressions, and here are the parameters:
Expression: (.*), (.*)
Replace: $2 $1
Skip Extension: Yes
