#1 2014-02-01 13:34
PabloM
Pascal script for Hex to dec
Please help me
Folder\file
first be removed from the title R,C
second step conversion name of hexadecimal to decimal (Pascal script)
Hex => Dec
#2 2014-02-01 14:54
Re: Pascal script for Hex to dec
No problem, below is the script to convert Hex in the filename into an Integer:
  FileName := IntToStr(HexToInt(WideStripExtension(FileName))) +
    WideExtractFileExt(FileName);
Note: Don't forget to remove "R" and "C" at the start with a Replace rule or similar, before applying this script.
#3 2014-02-01 15:25
PabloM
thanks cool:D:cool:
#4 2014-02-02 10:05
PabloM
and for the opposite case
thanks wink
#5 2014-02-02 21:43
For the reverse operation, integer to hex, use this:
  DIGITS = 8;
  FileName := IntToHex(StrToInt(WideStripExtension(FileName)), DIGITS) +
#6 2014-02-06 22:07
PabloM
this script rename names to upper case
I know the rule is to lowercase but I would need it in pascal
thanks
#7 2014-02-07 08:01
PabloM wrote:
lowercase in pascal
Just add another line like:
  FileName := WideLowerCase( FileName );
just above of the line with the "end."
Read more at
http://www.den4b.com/wiki/ReNamer:Pasca … g_Handling
http://www.den4b.com/wiki/ReNamer:Pascal_Script
