#1 2007-03-21 09:55
S1990xyz
Regarding the file number sequence?
Hi, All:
I have a question, I have a folder of files like below:
if I delete the 002.jpg and 004.jpg, And then I hope usage the ReNamer becomeing below like:
So, How can I do it?
Thanks!
PS: A folder maybe has 1000 jpg files, and maybe delete some jpg file, so I need filename to re-sequence.
#2 2007-03-21 17:06
Re: Regarding the file number sequence?
Hi there!
That's easy, just follow these steps:
1) add all files (after you've deleted few of them);
2) sort by "Name Digits" column;
3) use Delete rule from position 1 until the end;
4) use Serialize rule to renumber them again.
If you have any problems, don't hesitate to ask smile
