#1 2014-01-13 22:46
skates
Rearrange?
Hello, I'm a novice at RegX.  I have some pics to rename, e.g.
In the Summertime by Edward Dean Hopper
which I'd like to rename to
Hopper, Edward Dean - In the Summertime.
Any help would be appreciated.
Happy ReNamer User  :)
#2 2014-01-14 08:06
Re: Rearrange?
Hi.
1) replace "by" with "-"
2a) match all before and all behind the dash but the last word behind the last space (.+) - (.+ )(\w+)
2b) replace by $3, $2- $1
Tip: there some of this tasks already done and can be found in the forum and the wiki.
Search for regex and rearrange rule.
#3 2014-01-14 17:04
Re: Rearrange?
I would just suggest modifying the first rule to replace " by " with " - " (with spaces on both sides).
So to skip instances where "by" is a part of another word, for example: "goodbye".
#4 2014-01-15 01:44
skates
Re: Rearrange?
Thank you much for the suggestions. I accomplished what I set out to do thanks to your help.
