Hi, first of all I want to congratulate the developers of ReNamer for this excellent tool!
How can I rearrange a file name from "Surname, Name - Song Name.mp3" to "Name Surname - Song Name.mp3"?
Thank you in advance.
Hi pemartins, welcome.
Please see if you can get an use from http://www.den4b.com/wiki/ReNamer:Rules:Rearrange yourself.
It's easy if you know how,... as always.
If not, I will provide you the answer later (tomorrow?)
If you can't wait, here is the solution (encrypted):
To decrypt following message, browse to http://textmechanic.com/Encryption-Generator.html (needs JavaScript enabled),
paste this whole code, enter 2013 as password and click at [Decrypt]
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
http://www.infoencrypt.com/ works without JavaScript enabled, but was not always reachable:
To decrypt following message use http://www.infoencrypt.com
<Encrypted>
O0jHL/50VrmL9cEFMRksmc9brws4FjcgNBNgJiuz1StTFo1tqvXFKYqxmMLtT3lSynCE38AFhzO03hVCQMW8IyIMVkxmpSY6c80nh0l9CWsVQCN7Z9nekCQ35/4Cn2J06gXvWckZhNT2kPFhIUEGv7yN6bxoghQmkK6SaaSxFGbHi++2Kfqa4uBw7Hsqaxcup+xJ5LUUV7yTxQixm2wv5/OFpAZ4BWCfhfAeC0HXIqN9sm87L17mHEieXIKVtRLOUymcAGNnPkTvk4kTDyX6LE5fvyYgL7aT7BT51JRPYM3I0sjg3tygGWmLgIZIsR5i
</Encrypted>
HTH?
I think Stefan was trying to see if you can get it working yourself first before disclosing the solution...
What here really wanted to say is that you need to use a Rearrange rule in the following way:
Split by exact pattern of delimiters: ,|-
New pattern: $2$1 -$3
Skip extension: Yes
Thank you very much, it worked great!
Only a small problem that two spaces were being placed between the "Name Surname", but I solved it simply by adding a new rule in Replace, by Finding " " (two spaces) and replacing with " " (one space).
Thank you once again, keep up with the great work!
